2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
A friend sent this to me. About the Chevrolet Stovebolt Engine
An interesting read. And they mention Stovebolt.com. thumbs_up Worth the few minutes spent reading it.
An excellent article Kevin as well as the mention of our site! Thanks for sharing! thumbs_up
~ Dan
1951 Chevy 3 window 3100
V
VEW Offline
V Offline
Very interesting read. Thanks for sharing!
~ Victor
1957 3100 - moved on
Moderator
Moderator
2 Offline
Good read! I am interested in what Jerry has to say when he reads it?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
One thing I noticed that it talked about the spray oiler system for the rods on a 216, but no mention of GM going to full pressure lubrication on the 53 and later 235's. But still pretty comprehensive.
1 Offline
I found this more accurate than most of the enthusiast press on the subject of inline Chev engines. A few details were left out, though they probably wouldn't be of interest outside our group or perhaps Inliners International.
1951 3800 1-ton
In the DITY Gallery
Nice article!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Good info and interesting.
Wrong about the V6 first being offered in 1978.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Interestingly, there were multiple lines of General Motors produced V6 engines. The first Chevrolet V6 was introduced in 1978 as the article stated. It had a 90deg block that was based on the SBC. There was also a GM 60 deg V6 engines produced between 1980 and 2005 and used in a few Chevy car lines. Then there was the GMC truck V6 (305's and larger) produced between 1959 and 1974. And there was also the Buick V6 first produced in 1962.
Since the article was talking about Chevrolet engines, I'd say the other earlier production engines don't count.
