| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | hello,im not very inclined about tools,and i have a question about the mig welder.i just bought a easy mig 101/1.its has the outlet you plug in for power,but there a clamp i have to hook up to something,which i dont know what.so thats my question what does that clamp hook up to? a generator car battery?sorry that this post is so water down but like i said,im not inclined with tools.all help would be greatly appreciated.thanks
Its not a truck unless you can throw a dead cow in the back
| | | | | Joined: Jan 2002 Posts: 4 Junior Member | | Junior Member Joined: Jan 2002 Posts: 4 | Scott, I am assuming you are talking of the "work lead", also known as the grounding lead. This will need to be connected to the piece of metal you are welding. It is used to complete the circuit between your gun and the unit. Hope this helps.
Marvin '51 3100
| | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | yeahwish i had not made this post as i figured it out later.ah guess i need to mess around some more,but thanks i apprciate the help.and welcome to the board.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Dont worry with a little practice and patience your mig welder will become your best friend. They do real nice work on sheet metal. Did you get a regulator with your welder. I use straight CO2 on my mig welder, seems to work okay for me. Alot of people say to use CO2/Argon mix gives cleaner welds.  | | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | nope didnt get a regulator.i played with it today and really enjoyed.bestfriend,you bet its gonna be it has its work ahead of it
