8 members (Oswald, moparguy, tclederman, 2-Ton, Hotrod Lincoln, 1955 1 Series, Shade Baby, 1 invisible), 325 guests, and 6 robots.
Topics128,162
Posts1,057,056
Members48,463
Don't know what truck these side bed panels fit on. I know they are step side but what truck and year. Would like to find a new home for them. What's are they worth? Thank you for your help. Steve
They look like 1954/55 first series .look to be longer than the shortbed .The stamping were the fenders go are similar to my 54 .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
AD Addict & Tinkerer
The longer panels would be from a Chevy\GMC 3/4 ton or a GMC 1/2 ton long bed or if there 9’ long, they would be from a 1 ton.
Phil
Project Journals
Stovebolt Gallery Forum
I'm gonna say they're 1-ton judging from the distance between the front and the next stake pocket near the fender mounting. Also '54-55.1 from the fact that they have flat tops. I think I saw that the embossed areas for fender mounting are '54 only, but can't be sure about that.
I noticed that there are 4 stake pockets. Did the 1 ton have a 4th short stake pocket?
Phil
Project Journals
I found a ‘54 Chevy 3800 for sale that has the forth stake pocket, so I believe it’s for a 54-55.1 Chevy 3800. I included a picture.
54 Chevy 3800 bed side
Phil
Project Journals
Yep, 1-ton bed sides. Here's a pic of the Boss' (or is that Peggy's) 3800, showing the 4th stake pocket.
Thank you all for the info. Now I will have to measure the length and make sure there are for the 1 ton. Anyone know how long they should be?
From what I heard on this forum, they are nine feet. A 3/4 ton is eight feet and a 1/2 ton is about six, so if it’s closer to nine, it’s from a one ton.
Phil
Project Journals
Lazste - Below is a screenshot from the GM Heritage Center documents (same picture and measurements for 3800 pickup bed for 1954 & 1955.1) that can help confirm your parts. These are "Inside" dimensions. If your bed side panels measure over 105" long, they are definitely for the 3800 and 9' bed. smile
~ Dan
1951 Chevy 3 window 3100
From gmc Paul’s site shows the bed board lengths for one ton on the list
"The Journey"
Follow in the DITY
Moderated by  klhansen, Rusty Rod
