1 members (Peggy M), 39 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,422
#1562834 11/08/2024 6:31 PM
Truck is a '47 3600. Using the hood alignment procedure written by 52Carl. I set the hood gap at the cowl to1/8 in.
I keep pressure on the hood with a ratchet strap as I tighten the inner bolts. Two on each side.
I release the strap remove the 4 in. wood from between the hood and grill top. Then the driver's side of the hood the gap increases to about 5/16th. Passenger side stays where I set it.
How does the hood move when it is tight?
All front clip bolts are loose
weatherstrip is new
replaced the hinge without any change
If I had any hair I would pull it out...
chuck
old guy with old trucks
Check the hinge shoulder bolts on the driver's side hood. Another bolter having trouble with hood alignment discovered that his had been replaced with standard bolts, letting the hinge slop around way more than it should. Worn shoulder bolts or hogged out holes for them would also cause problems.
Thanks Kevin, the hinge bolts were replaced with the correct shoulder bolts and I chased the threads in the holes when I replaced the hinge. I had the same line of thought.
I use a short length of railroad rail (my makeshift anvil) on a bath towel to protect the paint. I put the rail in place after I put the 4" block in place, but before I loosen the hinge bolts.
As you loosen the hinge bolts, the weight of the rail will lower the hood down where it belongs.
One other thing I do to simplify things is to remove the outside hinge bolts completely rather than just loosen them.
