0 members (),
106
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Do all of these trucks leak and drip onto the floor by the kick panel? I left my truck out in the rain last night and have wet carpet this morning. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | I have a 1960 and mine never has. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I have a 1960 and mine never has. I did all the metal work. No holes, everything was seam sealed as well? I noticed some water was coming in the windshied rubber at the bottom. Maybe that is where it all has come from? | | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | If the windshield gasket is wet inside, it will find its way down either side to the kick panel area.
| | | | | Joined: Feb 2023 Posts: 378 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 378 | We did about 40 miles of driving in the rain Sat & had a little leak on both sides of the dash. Haven’t searched it out yet. Mom said she had s little leak under the dash on her side | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | If the windshield gasket is wet inside, it will find its way down either side to the kick panel area. Gotta be it. New windshield and new gasket........... How do you correct that? | | | | | Joined: May 2015 Posts: 11,070 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,070 | Did you use any sealant between the windshield rubber and glass and pinch weld? I had a gap in the sealant on my windshield install and it leaked at the center. Another shot of sealant fixed that up.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Heater core could leak into cab on passenger side. Of course that might be id'ed with fluid characteristics. But a possible source. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I have no idea what Portland Glass did. I have left a message in hopes they give me a call back to see what we can do bout it. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Heater core could leak into cab on passenger side. Of course that might be id'ed with fluid characteristics. But a possible source. Thats a whole other issue. The valve for the Old Air set up leaks any time the PSI build up in the coolant system. Been through two vlaves so far. | | |
