3 members (Chris's 46 / 515, 59 fleet, Wally / Montana), 138 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
Moderated
Moderated
New to site for posting but spent lot of time looking at the old post on how to put front disc brakes on a 1941 heavy Chevy truck = not sure if its worth posting. Finally came up with relative simple hack. have 1941 1 1/2 ton that I started working on a few years back. Frame off restoration but replaced engine with a 292 and t4 transmission out of a 1969 c20 and a dually rear end form a late 90s Chevy 3500. Have been stymied for a couple years on converting the front drum brakes to disc. Not much help out there and wasn't going to drop several K for a total front end replacement. After much alcohol one evening we figured out how to mount the Jim Carter 1/2 ton front disc kit to the existing hub and spindle. Only had to machine about 1/16th off the hub and another 1/16 off the rotor to ensure flush fit. Bore the holes to same diameter then install a 3/8 inch spacer center rotor between pads. All in for around $500. Anyone interested in old engine or tranny parts let me know or i will turn into yard art. Next I need to find a better front window frame as mine has cancer in bottom from sitting on uncles farm for 50 years. Thoughts???
hdpegleg, First off, Welcome to Stovebolt! shake That being said, your post is less a Welcome Centre introduction and more of a technical post that best fits in our Big Bolts forum, so it's been moved there in keeping with the site guidelines.
Feel free to post a new introduction to yourself and your truck in the Welcome Centre. Please post some overall pictures of your truck, seeing how you have already figured out that action. We do love to see them! smile
BTW - Before you do further posts, suggest you read through this helpful guide to get your posts to the best spots in Stovebolt.
Once again, Welcome to the 'Bolt! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Crusing in the Passing Lane
For nylock hardware to be effective one full thread must be protruding past the nylon device.
Ed
I have been knocking ideas around on what to do with the front axle on my 1946 Chevy 1 1/2 ton. I'm not that far in to the rebuild, but what you did there is a very interesting option. It is difficult finding information on the front axles, a lot of things to consider. Thanks for posting that.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
Crusty Old Sarge
Crusty Old Sarge
The only comment I have is a 1/2 ton brake assembly may not be heavy enough for a 1.5 Ton Truck. I went down the path with my 1958 1.5 ton. I found some larger brakes to adapt to the original hubs. The set up I have works great.
https://www.stovebolt.com/ubbthread...8-4400-disc-brake-conversion#Post1546538
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
A lot of the front and rear axle conversions I have heard of on this forum come from motorhomes.
I definitely agree 1/2 ton brakes are too light. If it was a daily driver that wasn't hauling anything other than the weight of the truck, maybe, but you are better off going heavier in your brake selection than lighter. The last thing you want is to not be able to stop!
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
Never hurts to go bigger, but that half ton setup already has about three times the heat dissipating capabilities of those old Huck brakes. If it's not hauling two yards of gravel down a hill every day, then those brakes are probably quite adequate. Because it's brakes, I might have gone with prevailing torque locknuts versus Nyloc, but if you torqued them to the correct value for the diameter, thread, and hardness of the bolts then they won't come loose anyway.
Wasn't there a guy on here a while back who had a disc brake kit for these trucks? His name escapes me, but I think it was Randy something.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Enclosed is a picture showing 1.375” x 14” disc assembly from GMC P-3500 HD truck mounted, kingpin out, on my ‘55 two ton truck. Looks exactly like Rich’s application. Larger disc, similar applications, as suggested in text appear to be possible, with minor machining and fabrication required, caliper bracket in particular. Air in system(HRL) allows pieces to be clamped together for design and marking.
Enclosed assembly is essentially a bolt up (Grigg), only fabrication required is new kingpin bushings($12.00)
Ed
Hey guys, I am still making front disc brake conversion kits for 1.5 - 2 Ton trucks. I'll do a for sale post. If anyone has questions, feel free to call, email or text me for details on the kits.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
