3 members (Hanks custodian, Steelonsteel, 1 invisible), 58 guests, and 0 robots.
Topics128,054
Posts1,055,780
#1562249 11/01/2024 7:19 PM
Im trying to find the bolt size for the right side ( transmission is in the truck) of the two cast “nipples” on the transmission case. I guess they were used to mount a hand brake(?) from what I’ve seen. Any help?
It’s a 1964 sm420.
I did a bit of searching through my reference books. Assuming you have the band style parking brake, the 2 bolts that are used to mount the U-shaped brake handle bracket to the body of the SM420 should be 3/8 - 16 x 7/8" and also uses 3/8" split style lock washers. My resources show the same info for 1958-62 SM420's and I think that will carry over to your 1964 model as well.
~ Dan
1951 Chevy 3 window 3100
Thanks. A quick ream out and that bolt went in like a champ!
Crusing in the Passing Lane
Almost all bolts in a Stovebolt engine are NC when threaded into CI. If threaded into steel are NF.
Ed
