victim=50 4400. itd be good to save ungodly amount of frustration to tack couple nuts on the bracket, if u got a tig welder. i felt so good putting it back together i even put the "those original screws" back in. thx.
Great idea! I wonder if rivet nuts would work also?
Thanks!
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
If the rivnuts extrude below that bracket, it would raise the key switch above the center of the hole in the dash.
Didn’t think of that. Thanks!
Love this collective!
