6 members (Otto Skorzeny, BarryP, Charles in CA, BC59, tclederman, 1 invisible), 122 guests, and 3 robots.
Topics128,140
Posts1,056,771
Members48,454
Putting my truck back together (slowly but not by choice) and today I was connecting the exhaust pipe to the manifold. My question is do you need a donut seal or a flat gasket for this connection? My exhaust pipe fits inside the manifold about half an inch and the flat gasket allows the exhaust pipe to fit firmly against the manifold. A few folks have told me I needed a donut seal but that makes the exhaust pipe stand off from the manifold by at least a half inch. The flat gasket seems to work better but I thought I should ask since I cannot find anything in the manual other than a system description..
Deegs
1953 3100
If your manifold has a chamfered depression where the exhaust pipe fits, then you probably need a donut seal. My exhaust pipe is flared to fit a donut seal that's tapered on both sides.
But if the manifold is flat at the connection, then a flat gasket would be correct. Link
Thanks Kevin. I will check to see what type of manifold I have.
Deegs
1953 3100
7
7 Offline
I have not worked on an inline six, didn't some of them have the beveled manifold and a ball flare on the pipe? in which case you would need no gasket or donut.
That ball and bevel was not used on any Chevy six I've ever seen. Either a donut, or a flat gasket, depending on the year of manufacture, IIRC.
7
7 Offline
Thanks Jerry, being I'm a young whipper-snapper without the wide range experience, I didn't know if that style was used. Probably 98% of my vehicles and experience has been GM V8's
I seem to remember the pivoting ball being used along with a spring-loaded flange to allow the pipe(s) to pivot a little as the engine rocks on a somewhat soft motor mount. It's seen pretty often on transverse-mounted engines that rock back and forth from torque reaction during acceleration. Older designs tried to keep the connection between the engine and the pipes more rigid.
