3 members (DaveV, Phak1, TUTS 59),
223
Mod | | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 72 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 72 | Putting my truck back together (slowly but not by choice) and today I was connecting the exhaust pipe to the manifold. My question is do you need a donut seal or a flat gasket for this connection? My exhaust pipe fits inside the manifold about half an inch and the flat gasket allows the exhaust pipe to fit firmly against the manifold. A few folks have told me I needed a donut seal but that makes the exhaust pipe stand off from the manifold by at least a half inch. The flat gasket seems to work better but I thought I should ask since I cannot find anything in the manual other than a system description..
Thanks Deegs
1953 3100
| | | | | Joined: May 2015 Posts: 11,138 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,138 | If your manifold has a chamfered depression where the exhaust pipe fits, then you probably need a donut seal. My exhaust pipe is flared to fit a donut seal that's tapered on both sides. But if the manifold is flat at the connection, then a flat gasket would be correct. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 72 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 72 | Thanks Kevin. I will check to see what type of manifold I have.
Deegs
1953 3100
| | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | I have not worked on an inline six, didn't some of them have the beveled manifold and a ball flare on the pipe? in which case you would need no gasket or donut.
| | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | That ball and bevel was not used on any Chevy six I've ever seen. Either a donut, or a flat gasket, depending on the year of manufacture, IIRC. Jerry
| | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | Thanks Jerry, being I'm a young whipper-snapper without the wide range experience, I didn't know if that style was used. Probably 98% of my vehicles and experience has been GM V8's
| | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | I seem to remember the pivoting ball being used along with a spring-loaded flange to allow the pipe(s) to pivot a little as the engine rocks on a somewhat soft motor mount. It's seen pretty often on transverse-mounted engines that rock back and forth from torque reaction during acceleration. Older designs tried to keep the connection between the engine and the pipes more rigid. Jerry
