4 members (Otto Skorzeny, Gray_Ghost, BarryP, Jeff Ogden), 117 guests, and 1 robot.
Topics128,147
Posts1,056,805
Members48,454
#1562087 10/30/2024 11:32 PM
Is there a resource somewhere that shows axle diameter and spline count for the torque tube rears?
The reason I ask...looking into the possibility of swapping a '57 center section into my '36 housing. From what I've learned here from others, it should bolt in, but what I don't know is if the axles are compatible. Been trying to research the spline count/axle size for my '36, but not having much luck.
The center section I located looks to be 18 spline.
Ron
The 36 Model FB ½ ton axle is 10 splines – 28 7/16 O.L. R\L.
57 ½ ton axle is 17 splines-30 5/8 Right, 29 5/8 Left O.L and a minimum diameter of 1.156
Would it be possible to swap the side gears in the differential from the '36 rear end to the later model center section? That might make it possible to use the original axles with the later model center.
I tried doing that with my 39 and it was a no go. The center section from the 57 uses hypoid gears, the 39 did not. The center section from the 57 would physically bolt into the 39 housing but the alignment was all off. I would expect the same with the 36 housing. GM started using hypoid gears in 40. In my 39, I used a 40 housing and axles with the 57 center section and all was good
I've mentioned elsewhere that my buddy used a 39 housing and axles in his coupe with a 55-59 center. That housing came from a frame he bought with no title, no cab/body to ID it from, so it seems likely it was a 40+ frame based on what Don said above. Pretty sure he hasn't bothered to look at casting dates or part numbers on it, though now I'm curious.
Well, ask, and you shall receive! Thanks for finding or sharing that. You guys are very resourceful. I spent quite a bit of time searching for something like that.
Thanks again.
Ron
