| | | Forums66 Topics128,279 Posts1,058,582 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2022 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 15 | Hi I have a 230 and a powerglide and I have a 46 3/4 T and a 1/2t spare frame. Being budget minded (poor) I'm thinking of using the 1/2T frame with the 230 I have and the Powerglide I have and mating to the torque tube diff/rear. I understand you can swap all sorts of things and wonder if this is possible - use the parts I own. The goal of this build is to putt putt to the Home Depot about 8 miles away occasionally and the cars and coffee sort of meets. It's a semi retirement project so not a huge hurry but would like some general direction. Thanks | | | | | Joined: Sep 2009 Posts: 6,228 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,228 | vonkluver, Are you talking about using an early cast iron Powerglide with the torque tube output??? I don't think the mounting pattern on one of those will match up to the 230 as that has the same bell housing pattern as the V8. The 230 Powerglide would be an open drive output requiring a different open drive rear axle. Not sure how you would mate the existing torque tube to the non-torque tube Powerglide??? If you are going to use the 230 and Powerglide, just go full open drive rear end and your cost will be much smaller than trying to do the adpation.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | The last torque-tube powerglide would have been 54. It was cast iron. I wonder if by some stroke of luck GM didn't change the tail-shaft bolt pattern when they went to aluminum. I also know the dry lakes boys like cast iron PGs because they are strong and don't use much power. There are lots of aftermarket power glide parts or there were last I looked, which is maybe 10 years so its possible that one could adapt an aftermarket cast Iron one to a torque tube but probably not inexpensive. all depends on parts interchange, which I'm no expert. Maybe put a post in the Hi Po forum. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Sep 2022 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 15 | Sorry its a PG from a 1967 Camaro aluminum version that I have in stock. I'll make some measurements and look at Hi Po forum | | |
