2 members (Nick in Manitou, 1 invisible),
342
7
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I picked up a neat electical troubleshooting tool recently that is kind of pricey ($80) but saves a lot of time tracking down problems. It is called a Power Probe. It is hooked up to a battery and has a 20' cord. Depending on which way you press the switch, you can introduce a power (+) or ground (-) into a circuit. It has a resetable 15A breaker so if you put 12V+ into a dead short, nothing is hurt. It also has a small lead that detects continuity, so you can test a fuse to see if it is good. I think you could make something that would do this job for less money, but it probably wouldn't be in such a small, compact package. | | |
