6 members (J Lucas, Hotrod Lincoln, Jon G, Otto Skorzeny, MikeE, ShopRag), 83 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#1561542 10/24/2024 1:13 AM
I just got the passenger door off and started sanding the inside. I had just got the door panels in today and did a fit check. Doesn’t fit. The inside handle sits too high. It looks almost like the handle mechanism is upside down. I went through the parts manual and couldn’t find a diagram showing it.
Anyone have a reference or had experience with this.
Picture below.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T Doug,
Please post what year your vehicle is… it looks like an AD door to me, but just want to confirm.
My AD’s door mechanism looks just like yours is set up.
Chris
O Online: Content
His signature says 1954 3100
1950 Chevrolet 3100 (Ol' Roy)
'54 ? The door mechanism looks correct.
Craig
AD Addict & Tinkerer
It appears from your question that you have two separate issues. First is the door panel not fitting and secondly is the interior door control.
First, the panel. Is it possible you are trying the wrong side upside down?
Second, you are experiencing the same issue that we all have with later AD trucks in that the control looks to be mounted upside down.
First a bit of history. In the early AD series the control was flipped over so the arm going to the latch laid nicely in the trough on the door so it didn’t interfere with the door panel. You opened the door by pushing forward on the door handle which wasn’t ideal especially in an emergency. GM engineers realized this wasn’t such a good idea when people started falling out of their trucks. In their infinite wisdom they decided by flipping the control they could reverse the direction the handle operated. Pulling on the handle would open the door. Unfortunately this caused a rubbing situation on the door panel. They addressed this by putting pads between the door and the panel which causes the panel to bulge out a bit, rather than reengineering the interior door to accommodate the new position of the control. I am sure GM’s financial department got involved in this decision, after all, it’s only a truck!
There is a workaround that I am going to use on my truck, if you don’t mind deviating from stock. You can use the passengers control on the drivers side flipped over so the control rod sits nicely in the trough and vice versa, using only two screws to mount it. Then flip the interior handle over so it is pointing up. Now when you pull on the handle it will open the door. Pushing on the handle will lock the door.
I’ve included picture of the original position of the door control. Looks the same as yours to me.
‘52 Drivers door
Phil
Project Journals
Stovebolt Gallery Forum
O Online: Content
What are all those holes in the door for?
Makes the truck lighter, therefore faster. wink
LOL
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
Your guess is as good as mine. Maybe super stereo speakers.
I did get a question answered by your picture though. I’m missing the inside trim molding for the window. But I’m moving along getting the passenger door done.
1954 Chevy 3100
Montgomery, AL
In Project Journals
Moderated by  ndkid275, Phak1
