Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Can anyone tell me if the emergency brake cables to the backing plates are the same for this Van as the 3/4 ton cables ?? I can’t find anything that references a 1 ton. Thanks, Dennis
Not the same as 3/4 ton. The Parts list doesn't differentiate between truck styles, just capacity. See the attached listing for Part code 4.826. It does show the overall length. The 1 ton probably isn't available as repops. You may have to fabricate one if the sheath is still usable. I think kits might be available with the inner cable and ends.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Dennis, The Filling Station offers a reproduction DS-600 1Ton Park Brake Cable that the description indicates replaces the original GM# 3697395 unit mentioned by Kevin above. Or you could repair your existing ones (if able) using the Filling Station AF-212 Universal Repair Kit.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
