8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15611 01/31/2004 6:59 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I've read some other posts but I'm still a little confused about my vacuum advance connection.
There are two places for vacuum on my Monojet. One on the carb base points towards the oil filter of my 261. A second is higher on the carb body and points towards the valve cover.
Should I connect the vacuum advance tubing to the lower one which points forward? What do you do with the second one? Was that hooked to an automatic choke which someone has removed?
Thanks!! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#15612 02/01/2004 1:48 AM | Joined: Jul 2003 Posts: 55 Member | | Member Joined: Jul 2003 Posts: 55 | Does the upper port have vacuum at idle? If not, then connect your vacuum advance to it and plug the lower port.
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI 1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
#15613 02/01/2004 5:26 AM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Wally.yes it is me me me,from the other classic truck shop. I won,t talk about anything for sale anymore.ha ha :p Im bleeding to death  I'll sell my parts at the swap meets.They don't have whips there.Now have a good day an watch your back.Big brother is watching us
dan-pa
#15614 02/01/2004 5:22 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | BigChevy66, The engine isn't running yet and the carb is from E-bay.
Dan, Got any photos of your truck? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#15615 02/01/2004 8:08 PM | Joined: Jul 2003 Posts: 55 Member | | Member Joined: Jul 2003 Posts: 55 | You'll be fine hooking it to the upper port. If it turns out to be manifold vacuum when the engine is running, then that's what you'll have to run. It's not a big deal. Good luck. John.
#15616 02/02/2004 6:10 PM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | wally photos of truck .www.classic truck shop.com go to photo gallery page 2.look for the seafoam 5 window,Breathin.I was going to send photos e-mail, but no address. It's a streetrod. 350hp+=700r4 tranny= 9" foord rearend, subframed 79 camaro front end.It will kick some butt  A little custom work,frenched headlites,antenna,ghost flames.Other than that,the body is all stock.Hell I be writin all day what's in this thing.But it's all NEW.And my son and I built this truck by ourselves complete=finished
dan-pa
#15617 02/02/2004 10:24 PM | | Anonymous Unregistered | | Anonymous Unregistered | I have hooked the vacuum advance to both places with the engine running and it didn't make any difference. I do not want to offend anyone, but my advice regarding a monojet is the same advice my father have me a few months ago: Throw it away, and buy a carburetor! I'm on my second monojet. This one is a new remanufactured, and it doesn't work any better than the old one. I simple aquired a different set of problems. I am switching over to a Holley-Weber 5200. You can get the details of this project under the post that says "I'm Gonna Try this ...." Bob | | |
