1st off - Welcome to Stovebolt, this being your first post and all (even though you have been with us a long time)! What kind of "info" are you looking for??? There are lots of resources available online and stuff in the various Shop Area Forums that you can find existing conversations about the alternator change (in the Electrical Bay), putting "FI" (fuel injection) on your 235 (Engine Shop and HiPo Shop) and in the Big Bolts forum for the wheel conversion.
Let us know what we can help with or post new questions in the best on-topic forum to begin gathering your info. Once again - Welcome!
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Thanks for the welcome. Yes, been a member but you know how it is. Kids, work, other unforeseen events. Time flies. Before you know it, you wonder where the time went. I’ve also got a 1962 GMC carryall I want to restore. Too many projects, too little time.
You might be interested in THIS. Some good basic info in there.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
If the specs are the same as 1960 it has 19.5 wheels
A 19.5 is a tubeless tire with an equivalent profile as an 18" tube type tire. The wheels in the pic are definitely 20" tube type, but I can't see enough of the rear wheel to tell if it's a RH-5 "widowmaker" or one of the relatively safe 2 or 3 piece "split rim" wheels with an outboard lock ring. Jerry
