1 members (klhansen),
114
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2023 Posts: 48 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 48 | Draining break in oil and changing for first time. So with the bypass filter on the 216 do you put 5 quarts in engine and one quart in filter can? Thanks, Lynn
Family truck 1953 1/2 ton w/216
| | | | | Joined: Oct 2021 Posts: 7,030 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,030 | Fill the crankcase to the level specified on the dipstick and then fill the oil filter canister.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 |
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I like to add 5 quarts to the crankcase, start the engine for a couple minutes, and then top off at the crankcase to the full mark on dipstick.
Skip the potential mess of adding oil to the filter canister.
1951 3100
