| | | Forums66 Topics128,186 Posts1,057,309 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 2,499 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,499 | Thanks for the work Paul.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | Gdads, not from the same server. From the same network. I have no problem blocking entire networks in China. They are more likely to be nefarious than not. Blocking entire networks in Europe is a lot more problematic. The problem is, when you block single IPs, the bad guys can just move to a different IP. So then you're playing whack-a-mole. When you list 217.113.194.XX, you're describing a class C network. I have no problem blocking them. If this continues, let me know, and I will block it. I've also decided to keep a much closer eye on awstats, because that can show us the bad actors very quickly. https://www.stovebolt.com/awstats/awstats.pl?config=stovebolt.comIf you click on Hosts/Full List, you will see the two Chinese IPs stand out. | | | | | Joined: Sep 2009 Posts: 6,034 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,034 | Paul, Thanks for the explanation as always. My limited knowledge in this continues to grow with your feedback and explanations. Those particular "Guests" were not showing up in WOL this morning. I will report further if they or something similar is discovered. Thanks you again!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
