3 members (Gdads51, 2 invisible), 60 guests, and 1 robot.
Topics128,115
Posts1,056,636
Members48,450
#1560795 10/14/2024 7:40 PM
1 Offline
I've done several searches and get a range of answers. What is the best oil to use in a NWC T5 transmission? Answers I have found: 50W gear oil, 75W gear oil, 90W gear oil, ATF.
1962C10 #1560799 10/14/2024 8:31 PM
Most I have seen say ATF.
1962C10 #1560801 10/14/2024 8:46 PM
Moderator, Electrical Bay
Yep, that's usually what you hear although somebody might show up to say gear oil is ok in the NWC transmissions. And they probably won't be mistaken, but it may depend on where they live. ATF according to everything I've read will cause slightly more wear on bushings, bearings, etc but we're talking tens of thousands of miles. Gear oil might make it wear a bit less but will make it feel pretty sluggish in cold weather.
~ Jon
1962C10 #1560808 10/14/2024 9:19 PM
What type of ATF? Dexron? Mercon V? Type F? CVT?
1950 Chevrolet 3100 (Ol' Roy)
1962C10 #1560825 10/15/2024 1:08 AM
The WC T5 must use ATF. A Stovebolt member was kind enough to reference his S10 Owner’s Manual and it said ATF for his NWC T5.
You will NEVER go wrong with DEX/MERC ATF, no matter what T5 you have, NWC or WC. The ATF called for in the 88-92 Camaro T5 was DEXRON II which is no longer available. Other DEXRON ATF choices are too thin. I’m friends with the owner/operator of a reputable T5 transmission shop in Atlanta and he said to use DEX/MERC ATF. I’ve used synchromesh in a NWC T5 but switched to DEX/MERC. I like it better. I’ve had people tell me their T5 wouldn’t shift properly with gear oil.
Lugnutz #1560839 10/15/2024 3:15 AM
When GM made the leap from dexron III to dexron VI it superceded all prior versions in automatic transmissions. Manual transmissions & shift on the fly transfer cases kept Dex III now relabeled as Manual Transmissions & Transferred Case fluid.
I would say that's what the Dex / Mercon is.
Dex VI is too slick for the synchronizer to function properly.
It is a huge leap forward in older GM automatic transmissions!
BC
1960 C60 pasture art
1962C10 #1560859 10/15/2024 4:15 PM
1 Offline
Looks like it will be DEX/MERC. Many thanks to all for your help.
1962C10 #1560898 10/15/2024 10:43 PM
I concur. Dexron/Mercon is what I use in the Cadillac and Toronado after Dexron II disappeared.
1962C10 #1560901 10/15/2024 10:52 PM
I’m glad I read this thread. I thought ATF was only for the world class t5 trannies.
1951 3100
1962C10 #1560904 10/15/2024 11:19 PM
K Online: Content
Yes finding fluid for the T5 was a confusing search. I am using synchromesh MT currently. No issues to date.
1962C10 #1560976 10/16/2024 7:31 PM
I had my NWC T5 rebuilt by a local manual transmission shop. The guy recommended 30W oil. I double checked to make sure I understood what he meant when he wrote that on my receipt, confirmed we were on the same page... 30W oil.
Five years later, still good. I haven't been in it to look at wear but it is driving as nice as can be.
1962C10 #1560985 10/16/2024 8:32 PM
When I first got my T5 everyone (including the Chevy site) said to use A/C Delco 10-4014 (Synchromesh friction modified). So that's what I did. It is a NWC. Are people today saying that's not good?
~ Jon
