9 members (Gdads51, Shaffer's1950, 78buckshot, Phak1, Leo, dt235sd, Jon G, mick53, 4tttt8), 87 guests, and 4 robots.
Topics128,181
Posts1,057,180
Members48,465
#1560710 10/13/2024 11:08 PM
Hello all. I've rebuilt the the steering gear box for my 1950 3800. My question is, what lubricant was used? Thanks in advance...Clint
Typical recommendation on this site is Deere corn head grease or 00 grease, pretty thick and somewhat sticky stuff…
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
I mixed together really well in a old ice cream tub a tube of 00 grease and half a cup of amsoil.
Scooped it into a sandwich bag sniped the corner and squeezed it into the gearbox until it was full to the plug.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Thanks to those that replied. That is what I will use. Next question, was the Steering column painted the same color as the interior, or were they painted black? Thanks in advance.
AD Addict & Tinkerer
P Online: Content
Another choice that I used in my truck, works great, easily available and cheap.
Steering Box: Grease 00 weight: https://www.tractorsupply.com/tsc/product/super-s-cotton-picker-spindle-grease-00
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 #1561737 10/26/2024 11:37 PM
What I use. At $6.19 a quart the price seems fair. One tip, this stuff is flowable, but SLOW. I put the plastic bottle in a pan of water and turn the heat on low. About the time the water starts to bubble it's ready to head to the shop and fill the steering box. Without this step, you'll squirt a couple thimble fulls into the steering sector fill hole, it'll look full, it's not....take a screwdriver, stick it in wiggle it a bit and when you pull it out the 00 grease will slowly ooze down, keep repeating all the while asking....Why did't I just heat it up?
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
The steering column in my 1951 3100 is interior color both inside the cab and on the column in the engine compartment down to where it attaches to the steering box.
~ Dan
1951 Chevy 3 window 3100
Moderated by  Dusty53
