4 members (Shaffer's1950, Oswald, JJs55210, 1 invisible), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1560675 10/13/2024 7:10 PM
Converted to 12v and halogen reflectors using relays wired like the first picture. It all made sense. Could not wrap my head around how the horn relay would work as it works though the switch (horn button) as a ground. I found the second picture on Google but with no explanation of circuitry. Wanted to check if this is what I’m looking for the horn before smoking something. Wire coming out of the steering column is the “switch” that is called “trigger” connects to #85 and #86 is hot instead of being a ground?
Headlight relay
Horn relay?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1560680 10/13/2024 7:39 PM
Yes, that horn relay wiring is correct.
The relay will only trigger if it has both power and ground.
For the headlights, the ground is always connected and you are switching the power.
For the horn, the power is always connected and you are switching the ground.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
37 GC #1560684 10/13/2024 8:05 PM
Thanks, making sure rather than make sparks.
Larry
