4 members (texas46, eclector, Otto Skorzeny, KEVINSKI), 190 guests, and 0 robots.
Topics128,100
Posts1,056,178
Members48,436
What 1937-39 GMC trucks were equipped with the Oldsmobile flathead 6 cylinder 230 engine? A recent conversation in another thread seems to indicate that 1/2 - 1 ton trucks used a Pontiac 223 flathead (at least for 1937-38).
Reason I ask is I came across an NORS water pump made by Warner Machine Products Inc, Part# P-28 (seems to be from around 1950 per documents in the box), that says on the label it fits 1937-39 GMC trucks with "TYPE 230 MOTOR", in addition to fitting 1936-48 Oldsmobile 6 and 8 cylinder engines. Can any of our GMC guru's help with info on what trucks this water pump would fit???
~ Dan
1951 Chevy 3 window 3100
Dan: My books only go back to '39, but notice the "408065V" number on the box under "Replaces". May be a good hint.
1937-1938 the T14 (37 only), T-16, T-16H, F-16 and F-16H use the OLDs 230 CID. Midyear 38 a 1 1/4-ton walk-in panel delivery van. 1939 AF-230 use the 230 OLDs. GMC 228 and 248 replaced the Pontiac and OLDs engines in 1939.
P/N 409545
Body casting number 408066 and 416430
Bill, Thanks for the hint. smile I did see it, but I couldn't find any resource books that confirm what that goes to. My best guess is it's an Oldsmobile Part Number, but will need to ask that question elsewhere to try and get confirmation.
~ Dan
Originally Posted by jimgmc
1937-1938 the T14 (37 only), T-16, T-16H, F-16 and F-16H use the OLDs 230 CID. Midyear 38 a 1 1/4-ton walk-in panel delivery van use the 230 OLDs. GMC 228 and 248 replaced the Pontiac and OLDs engines in 1939.
jimgmc, Many thanks for those tidbits of info! After doing a little more web searching I see that the T-16 and F-16 models were the larger trucks as I came across some copies of dealer handouts indicating they were 1-1/2 and 2 Ton sized trucks. Saw a Dealer handout for a 1938 GMC "Special Delivery" truck that said it used the 230 engine also.
I think I am going to do more research to try and confirm what trucks this pump fits before I do anything else as I want to make sure it is accurately identified. smile
~ Dan
408066 is the GMC part number, It only fits the 203 ci engine, it will not fit the 1936 213 engine.
1936 GMC T-14 1/2-Ton Pickup
dunfire, Did you mean "230" instead of "203" and "223" instead of "213" for the 1936 engine? Just want to make sure I'm understanding what you meant? wink Thanks!
~ Dan
Yes, I did mean 230 however the 1936 engine is a 213. Sorry for the confusion
Thanks for the updated info. Very much appreciate your sharing your knowledge. shake
~ Dan
