8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I'm planning to spend a lot of time on the wire wheel cleaning up the old original rusty nuts and bolts when I start re-assembling inner-outer fenders, bumpers, bed, etc.
Outside of purchasing new bolt sets, anybody have a better way?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | If you can afford it get yourself a blast cabinet. Best money i have spent. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Go to the bulk food store and buy 10 bucks worth of citric acid mix a tablespoon up with a ice cream pail of warm water let it sit overnight with your items in there ,you should do a quick wire brush to get the loose stuff off but as long as the bolts are not greasy they should come out rust free . | | | | | Joined: Jan 2022 Posts: 2,450 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,450 | A vibrating tumbler and some ceramic deburring media would do a nice job.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | I used Evaporust to remove the rust, then a rock tumbler with sandblast media in it, and then zinc plated the hardware I was planning on reusing. But for the fenders and most of the front clip, I used new bolts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Thanks for the suggestions. I think I'll check out a vibrating tumbler today at Harbor Freight. I'll let you know
Besides zinc plating, is there anything else you can do for the threads?
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | If the threads are messed up, you can either chase them with a die, or just toss that bolt into the scrap bin and use a new one. I went with new bolts so I didn't have to fight with binding nuts. The fender to cowl bolts are hard enough to get to without saddling myself with having to use a wrench to spin the nut down ALL the way.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | Another thing to consider, and I’m not an engineer, is bolt stretch, possibly better defined as stress or fatigue. I realize high torque is what stretches them and in the case of fender attachment might not involve high torque, but it’s worth considering getting new unused bolts. 1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I enjoy wire wheeling on a bench grinder on a pedestal. I also enjoy the Easter Egg Hunt looking for slung parts in the shop. For some reason I have a special attachment to everything about these old trucks and like to re-use as many original fasteners as I can. I soak small parts in mineral spirits and use a toothbrush to knock the oil and road filth of up them, then wire wheel them to remove rust. I then wipe them down with acetone or lacquer thinner before priming and painting.
| | | | | Joined: Jul 2021 Posts: 214 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 214 | I saved as many of the clutch head and other light hardware as possible soaking for hours to days using Costco purchased lemon juice(cheapest). Maybe some light sanding to minimize the pitting look. Then a toothbrush to finish. I have lung issues, and that seemed to be the mildest de-rusting chemical I've found. The rest of the structural hardware for me was so far gone that a full stainless nut-bolt-screw kit is being used. Much cheaper and easier than single purchases. With a sandblasting on the exposed parts of stainless to make it look like old cleaned up standard hardware. If it is NOT major structural, I'd say a de-greasing then de-rusting, as long as the nuts aren't too loose on the bolts.
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | | | | Joined: Sep 2020 Posts: 449 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 449 | I second evaporust, seems to have no fumes or toxic-ness ang it works! Just wire,wheel after and reinstall. A blasted part will rust asap. On I project I set up a nickel electroplate dip, worked awesome
Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Speaking of clutch head bolts and screws, I have found a way to fix a buggered up one by putting it in a vise with copper inserts to protect the threads and hit the top of the head with a body hammer to mash the buggers back in place. As long as I can tighten it back into place with enough force to hold, and it looks right, I'm good with it. I doubt that I'll ever have to take the vast majority of them back out ever again.
| | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Thanks for all the advice. Good stuff. 52Carl you prime and paint the bolt head and threads?
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I don't worry about getting primer on the threads. Paint on top of primer can be a pain.
| | | | | Joined: Jul 2021 Posts: 214 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 214 | After cleaning/de-rusting, I've shot rattle can flat clear on bolt heads to keep the rust from developing again but maintaining the natural look. Mostly for very visible bolt/screw heads.
Chip
