3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
Does anyone have information on where to find eaton 16600 diff cover gaskets. It's roughly 17" across and 12 bolt pattern.
Thanks in advance for any and all help
Phil
1951 GMC 451
1964 International Harvester v190
3B Offline
Hy Saw Mill, my Fel-Pro catalogue lists their p/n RDS 5817 as the cover gasket for an Eaton 16600 differential, hope that helps
3B,
Thanks for the info. I did a search and came up dry. It appears that they no longer list it on their website. Will continue to search with this number. Thanks
1951 GMC 451
Crusing in the Passing Lane
A Manila folder makes great gaskets!
Ed
7
7 Offline
I made the gasket for my Chevrolet 15000 lb. axle when I swapped the pig. 13 bolt, odd number isn't it?
I've made one from a boot box before.
BC
1960 C60 pasture art
You could probably use permatex gasket maker on there without any issues.
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
I would use RTV. Before we had RTV we used to leave about a1/8" gap between the cover and the housing. Then we wrapped several rounds of cotton string around the whole thing and then tightened it up. We did this on both the cover and the third member and it lasted until we had to take it apart again.
Finding old cork gaskets is an endeavor you likely wont win. As Ed and Puffie40 have said, manila folder and/or RTV gasket maker are your friend. Be sure to check as some axle diff cover bolt holes are through holes and will need the threads sealed up with RTV or they will slowly weep.
When you assemble, coat both mating surfaces with RTV and mount with the bolts just beyond finger tight. Wait 2 hours and then tighten down to correct spec (wont be much).
1964 Chevrolet C60 Real Farm Truck
in Gallery Forum
HFfarms,
Thanks for the direction.
1951 GMC 451
You do not need much RTV to form the gasket. Excessive squeeze-out breaking off inside the housing and causing chaos with pressurized oil systems is why a number of mechanics do not like it. You just need a layer just thick enough that you cannot see the metal beneath. There should only be a minimal amount of squeeze-out if you did it right.
Surface preparation helps as well. I wire brush or scrape the surface clean of crusty stuff (down to bright metal if necessary), and wipe the surface with a little bit of brake cleaner before I apply the RTV.
