0 members (), 96 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
Moderator, Electrical Bay
Occasionally I need a piece of shim stock that is .0005", .001" or .0015" thick and maybe some of you out there do also. Slogging through Covid hasn't been any fun nor in any way entertaining but one discovery came to me. There is a good source of metalized .0015" shim stock and like two other things I'm going to tell you about this morning...it is in some ways free. Please see the first image below. That's right, it is the wrapper of a common Lay's small snack bag. Maybe the large bags are the same, but the individual sized bags are made with metalized mylar polyester which is .0015" thick and very uniform. If you need .001" you can straighten and use the wrapper of a Hall's Mentholyptus throat lozenge. Those are made of plasticized paper and are a uniform .001" thick. If you have any common wrapped starlight peppermints, those are often wrapped in .0005" thick cellophane. I'm putting this in the engine section, because that's where most discussions about machine work take place. If you think it needs to me moved please feel free.
I'm still watching for some common metalized item which is .001" or .0005" thick but haven't seen it yet. McMaster-Carr has it (stainless steel), but it is rather costly. And there are sellers on eBay with some but much of it is either paper-based or totally plastic. Okay...back to the low fever, chills, aches, coughing, runny nose, etc. Such fun.
~ Jon
AD Addict & Tinkerer
First, get well my friend! Don’t like to se you having such “fun”!
My first question would be “How does the plastic react to the heat in an engine”?
Phil
Project Journals
Stovebolt Gallery Forum
I'm working on recovery but I hear it just takes time, Phil.
Cellophane is impressively tolerant. It can not (naturally) be used between moving parts but it can be used between a bearing and some other part, actually (like a crankshaft main bearing and cap or saddle). It is inherently stiff with an elasticity of 750 kpsi (5200 MPa). It has high temperature resistance (typically up to 177°C or 350 degrees F), excellent moisture and oxygen barrier and oil and grease resistant over a long time. As for the plasticized paper, I'm not certain and I haven't found data because there are many different types. The snack bags are pretty hard to destroy, actually. That's why the tree-huggers get all apoplectic whenever they're mentioned.
~ Jon
Good info, Jon, and you have my sincere regards concerning your covid recovery.
John M's 261 engine that we built a few years ago needed one shim on one side of a main bearing cap to get the right oil clearance on that particular bearing- - - -it's proudly wearing a slice of an aluminum beer can there! Since then, I've bought an assortment of brass shim stock, 12 inches square, in graduated sizes from .001" to .015". That's going to be a lifetime supply for me, and probably my grandkids as well!
Interesting! Never thought it was that heat tolerant.
Phil
Project Journals
Plain old brass shims have worked well for over a century- - - -is anyone really willing to bet the life of his antique engine on a junk food bag? That doesn't make good nonsense to me!
www.ebay.com/itm/124714257478?
13 bucks- - - - -with free shipping!
Or you can get peelable 4 layer -.002 brass shim stock from McMaster-Carr at about $30 for an 8"x24" sheet. Same stuff as GM originally used. Cheaper than the precut shims that the vendors sell, but you would have to cut them yourself.
1 Offline
Does anybody have a source of tapered shim stock that we used to use to shim bearings? I still do and I have only enough left to do maybe one more engine.
1951 3800 1-ton
In the DITY Gallery
I've seen it sold on Ebay at times- - - -usually called "feather shims". It's twice as thick in the center as it is at the ends, so the ends of the bearing shell don't get pinched tight against the crankshaft. Search "taper shim bearing adjuster".
www.ebay.com/itm/135196303053?
