| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I was successful with the "ole bread pounded in the pilot bushing hole removal method" this morning. It took almost an entire slice of white bread, but I was able to walk it right out with a piece of round stock Delrin plastic, pounded in the hole with a BFH. You just pack it, pound it, pack it some more, pound it some more and out she walks. No muss. No fuss. The process created a small wad of dough which was a perfect impression of the pilot bearing and the recess in the crank behind it. I'm think about baking it and scrape off the engine grime. If it still stinks, I'll feed it to the dog. I am certain that she will look at me after, wondering if there are more.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Use a big threading tap, one that will cut into the bushing, and keep turning when it bottoms out in the crankshaft counterbore. The bushing will walk right out. Save the bread for a sammich! (which your wife should have made for you, along with an ice cold beer!) Jerry
| | | | | Joined: May 2015 Posts: 11,001 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,001 | The downside of the tap idea is you either have to already have one or go buy one. Bread is nearly free. [on edit] I just remembered another bread trick we used to use. When soldering copper pipe that won't quit dripping, stuff some bread inside the offending section of pipe, then sweat the joint. It's impossible to get a good sweat joint if there's any moisture inside. The bread flushes out after turning the water back on.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2014 Posts: 4,478 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,478 | I just use wheel bearing grease and a wooden dowel rod the same size as the hole. Back in 1965 I saved the input shaft of a ruined transmission and I used that until I lent it to somebody who decided returning it was too much trouble. Occasionally I'll wrap a bit of masking tape around the dowel rod if the bushing is worn badly (to make it tight).
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I've also used a pipe tap and a grease fitting adapted to thread into the bushing. Then a hand pumped grease gun does the job without any hammering. My tap and die assortment goes up to 1 1/8" NF diameter, which is a pretty popular barrel thread on custom rifles. Jerry
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Many years ago a buddy told me to use a bar of soap and drive it in there. I was pleasantly surprised when it actually worked!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I was able to eat most of the crust. We're out of beer and the Mrs.is 900 miles away helping her Paw take care of Granny. Ain't got a tap big enough, and I didn't want to have to clean metal bits or clean up any grease. As easy as the bread trick was, I wouldn't bother trying any other method even if I owned a machine shop full of tools. It was as slick as snot. I am certain that I heard about the bread trick on this site, but at the time, I thought that it was too good to be true. It was glorious sitting there afterwards, leisurely consuming the crust from that most useful piece of Wonderbread.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There are official pilot bearing pullers made for that purpose, also!
Ed
