4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I have a compressor pump that a neighbor gave to me and I have a two hundred gallon propane tank to use. Now my question is, since I know less than nothing about setting this thing up. I am posting a link and in it you will see the pump. The wheel in front is over a foot in diameter(so you can tell this thing is real big) The outlet for air is on the back right and it pumps so much air you can't keep your hand over it for two revolutions of the wheel. 52pickup, when he was here, told me that an electric motor would work on this pump. What size motor should I be looking for? What will I need to fix this up for my shop? I need to be walked through this one step at a time because I am out of my depth on even what questions to ask. Any help will be graciously appreciated and always returned in kind. I want to run both a paint-body shop and drivetrain shop off from this setup. here is the picture, it isn't very good but I can't lift it by myself. compressor pump
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Oly , I think you will need to figure how much CFM it will pump ( may have to lift the head and measure bore and stroke ) . Then work out how much power will be needed to drive it . | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Headline.. Man killed by "Air" Bomb in garage! Man, your asking for trouble here. Think it's better insurance to buy ready made unit myself. Anyway, maybe go to Library and check on books on "Fluid" control or Hydraulics or something to get math formulas and tips on something like that. Write the manufacturer of pump if a name or model is on it anymore for specs. I bet that pump isn't as big as you think in output. Thats a small pulley on it. You will need the fan or A fan on it to keep it cool. AND, where you gonna get a wide ribbed belt like that? Bet that's outta a ship or commercial system. You have 3-phase in garage, bet not. Most big motors will need that to keep from using all available juice you can make/get on it. Find a body shop going outta business, buy there's. That happens quite often I think. Pump may be a two stage where one cyl pumps up to some pressure and second one takes it rest of way and to tank. You would need that if you have a big tank or it will take forever to fill it. Don't forget safety valve and shut-off switch. What about a water drain valve? Won't be one on Gas tank will there? Can't weld in a "bung" for one with fuel in it to "blow". Sorry, I don't like this idea at all!  :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | i've seen this done before. gotta have water in the bottom of the tank--no welding--drill and tap the bottom for the drain. cutoff switch available from ww grainger. bet the motor will have to be close to 1 h.p.. 220volts. remember propane impregnates the steel, ethyl mercapatain makes the smell---not the gas, so just cause you don't smell anything......  | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I wouldn't even want to try to drill that hole. We had two kids in high school that tried a similar stunt, they were lucky to have any fingers left after the drill got hot.
Fred 52 3600 69 C-10
| | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | | | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I have recieved a common-sense answer to the hole problem from 52pickup. This is almost as bad as a Canadian Joke-LOL- Turn the tank over and use the hole that is already there. Works for me.
Now, I have come by an electric compressor with a 21 gal or so tank. Question- Can I use the hardware from it on the bigger setup? It has gauges and all. Then I need to borrow a "sky hook" to move the pump and tank.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Can't tell for sure, but looks like a twin cylinder single stage compressor. You may need to find displacement of cylinders to determine the size motor you will need. You should be able to use parts from the other compressor to assemble this compressor. Make sure you use safty valve on your compressor.  | | |
