0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | Looking for any info as to production data of my 1960 C10. It was sold new in John Day, Oregon in Nov. 1959, s/n puts it in the first 1,000 vehicles off the line. Thanks
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 |
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | Thanks but those just decode the Vin, what I'm looking for is production date for my 1960 from the Oakland assembly plant. 918th rig off the line.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 |
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | BC59, It sounds like you do not have the serial number from the driver's pillar plate or on the front RH frame rail above the front spring?
If you have it, once decoded, it would tell you plant location, year of truck, size (half ton, 3/4 ton, etc), month it was officially produced and then the production number.
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | BC59, It sounds like you do not have the serial number from the driver's pillar plate or on the front RH frame rail above the front spring?
If you have it, once decoded, it would tell you plant location, year of truck, size (half ton, 3/4 ton, etc), month it was officially produced and then the production number. cmayna, I think BC59 has all that. What he is looking for is the number of 1960 C10 trucks produced at the Oakland plant. Something that it doesn’t seem GM did a good job of in record keeping or providing such data to the public. Some folks have found full year production data for a few years, but that for the most part was only national production totals, not individual plant counts. Bill Hanlon’s suggestion to reach out to the GM Heritage Archive I think has merit. It may take some emails, phone calls and persistence to get an answer, but that may be the only source capable of providing such numbers.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Dan, He says above that he is looking for the production date of his truck. I assume the production completion date. None the less, hopefully the link Hanlon provided will help.
Craig
| | | | | Joined: May 2015 Posts: 11,137 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,137 | I just looked at the 1960 Vehicle Info Kit and the serial number doesn't appear to decipher the month of production like the AD series does. But if 1001 is the starting serial number each MONTH, then it could have been produced in any month of the year. Some clues to the production date would be on rear axle, transmission, and engine serial numbers, which do include the month and day of production. An early production 1960 would likely not have a late production rear axle and transmission, assuming they hadn't been changed.
For instance, my 51's serial number 6JPD 7565 indicates the following: 6=Oakland plant J = 1951 P = 3100 D = April 7565 = 6565th truck off the line. I believe this number started at 1001 EACH MONTH as the yearly total would be around 150,000 for the Oakland plant which I'm guessing to be roughly correct. Comparing other 51 AD serial numbers would confirm that supposition. I've seen a '50 2 Ton with a serial number of 9TWE 2893, Norwood plant, 6400, May production, 1893rd truck off the line.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | I'll just keep on celebrating my birthday in late September 1959 with oi'blue.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | I just looked at the 1960 Vehicle Info Kit and the serial number doesn't appear to decipher the month of production like the AD series does. But if 1001 is the starting serial number each MONTH, then it could have been produced in any month of the year. Unit numbers for 1960 started at 100001 for each model and continued in sequence through the entire model year...Chevrolet never reset the unit number each month. Mike B  | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Looking for any info as to production data of my 1960 C10. It was sold new in John Day, Oregon in Nov. 1959, s/n puts it in the first 1,000 vehicles off the line. Thanks If your unit number is 100918, than it was the 918th C10 off the line, but there could have been thousands of cars built ahead of your truck. Your serial number should look like this 0C144O100918...am I right? Mike B  | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | Mike, I thought the truck s/n & car s/n were separate production lines. Any idea when the '60 model year productions started?
