1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
#1558973 09/26/2024 1:50 AM
I found two Carter carbs in my dad’s stuff. A WA-1 and a W-0. I sprayed some WD40-40 on them and the choke and throttle plated both came free easily. What vehicles would they be from? Are they worth anything to someone to repair? I will never use them.
1947 3600 Chevy
According to carbking's website HERE those were used from 1932-1949
I've seen a W-1 on an unrestored original 48 or 49 (don't remember exactly which year) AD truck.
Maybe carbking will be along to tell you what they were used on.
See if there’s a little triangular brass tag on the WA-1 and post the numbers here. That model carb has been mentioned as an option when the right YF cannot be found at the right price.
But the WA-1 was used across quite a few different makes/displacements and would need to be a relatively close “CID” match to work on a Stovebolt.
1951 3100
Carburetion specialist
I have 118 listings for Carter type W-0 carburetors, used on engines from 44 to 214 CID.
I have 161 listings for Carter type WA-1 carburetors, used on engines from134 to 308 CID.
Some are in demand, others not so much. Would need to positively identify to determine desirability.
Jon
The Carburetor Shop
Did not find brass tags. there are however numbers stamped on the bottom casting
1947 3600 Chevy
The numbers stamped on the underside of the throttle body, together with the numbers cast on the metering rod, will get you close, if you can find the interchange.
Jon
The Carburetor Shop
