1 members (walter74),
78
Mod | | | Forums66 Topics128,096 Posts1,056,477 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I would appreciate ID and details on the trans. out of my 1965 C10. I think it is a Muncie 318?
Case # 3830210
Tail shaft 3844067 [last 3 very hard to make out but I believe it is 067]
Side cover 3845157 GM
Thank you
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Standard 3 speed manual short tail housing transmission. Muncie 318, non syncro first gear. Common to cars from 58 through 65 and trucks from 63 through 66 (67 with a 6 cylinder). Earlier vehicles had a long tail housing. Trucks had threaded lower mount holes, different side cover from cars. Fred
