| | | Forums66 Topics128,086 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I'm installing a '95 lt1 in my 1950 Chevy. Just wondering if there are any issues connecting the brass line from a fitting on the engine to the original gauge? (Using aftermarket original style gauge converted to 12 volt. I believe the gauge reads 0-60. | | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | The original gauge was/is mechanical using the steel tube from the engine to the gauge to relay the pressure. The LT1 engine should have a threaded port on the rear of the block or possibly one near the oil filter. The sending unit should thread into the port but if there is not enough room you could mount it remote and run a line to it, the kits that are available normally have either copper tubing or nylon tubing, I prefer the copper. I am a little confused on your installation, is the new gauge mechanical or 12 volt electric?
| | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | 78buckshot...just to clarify...the gauge CLUSTER, i.e.,fuel,temp,oil and dc will be upgraded to 12 volt, the oil pressure gauge will still be mechanical. | | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | That should be pretty straight forward, only thing to be concerned about is the actual fitting for each end. Some are a compression ferrule, some are a type of "flare" nut with the compression surface as part of the nut. Do you know if the engine has a high pressure or high volume pump, it might peg the 60 psi gauge when cold.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | The relief valve on an LT1 is set to 75PSI. I don't know if that much pressure will damage the old mechanical gauge or not. | | | | | Joined: Dec 2020 Posts: 1,966 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,966 | That should be pretty straight forward, only thing to be concerned about is the actual fitting for each end. Some are a compression ferrule, some are a type of "flare" nut with the compression surface as part of the nut. Do you know if the engine has a high pressure or high volume pump, it might peg the 60 psi gauge when cold. Yes ,if its a high volume oil pump. I`ve had one in my 327 for 5 years now and it was tested separate at 82 psi. Pegs my original mechanical gauge out driving. No damage. It idles at 30psi.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | In a typical street engine, not built specifically for high RPM, high load abuse, all you need for oil pressure is roughly 10 psi per 1000 rpm. If a high volume or high pressure pump is installed in an otherwise stock engine, you will more than likely end up with uncontrolled oil burning/consumption and possibly bearing erosion.
