5 members (2-Ton, Hotrod Lincoln, Jims46, Otto Skorzeny, Maybellene), 68 guests, and 6 robots.
Topics128,181
Posts1,057,152
Members48,464
Hello,
what´s are your tune up/ignition values for I6, 292 cid engine with a Rochester B carburator (only manifold vacuum port).
My base ignition with unplugged vaccum advance is @600rpm = 8° and @3000rpm 22°
I had to change my stuck vacuum advance mechanism and got now an adjustable vacuum control.
Sven
1947 Chevrolet 3800 1-ton long bed
292 cui, GM 14 bolt rear-end, 4 x disc brakes
In Frankfurt, Germany
Pictures in the Forum Gallery
Sven, I've got some info to respond, but before I do your question will get better replies and help in the Engine Shop forum so it has been moved there. Back in a bit. smile
~ Dan
1951 Chevy 3 window 3100
Sven, Below are a couple of pics from a 1968 Chevrolet Chassis Overhaul Manual that provide ignition timing and distributor advance specifications (outlined in red) that should help answer your questions. If you can provide more details on the year of your 292, we can check further to make sure these remain accurate for your engine. smile
Last edited by Gdads51; 09/11/2024 2:05 PM. Reason: replaced pictures with better quality shots
~ Dan
Thank you for the datas. The engine is from 1964 with a HEI distributor.
The 0° /TDC are a bit strange for me.. idle rpm @700, too. What do you think?
Is the engine still in stock form of has it been rebuilt and bored over? If bored over then manuals specs are a starting point, but then it takes diligent testing to get it all right.
22* total advance at 3000 rpm seems pretty low for the 292 even for a heavy truck application which you aren't.
My '64 292 that's punched 0.040 over with HEI and Rochester B is in a C60 and factoring in a loaded truck at 20,000lbs, likes 7* initial timing and slightly weaker mechanical advance springs that bring in timing at 1050 rpm with full advance of 36* around 3400rpm.
On points and without a load, the same engine quite frankly LOVED initial timing at 10* and stock 292 advance springs which followed the factory advance curve.
1964 Chevrolet C60 Real Farm Truck
in Gallery Forum
My '64 292 that's punched 0.040 over with HEI and Rochester B is in a C60 and factoring in a loaded truck at 20,000lbs, likes 7* initial timing and slightly weaker mechanical advance springs that bring in timing at 1050 rpm with full advance of 36* around 3400rpm with vac advance.
Thank you. I will adjust the initial timing and vacuum advance to reach this values and will see how it works thumbs_up
I don´t know something about the history of the engine....
Do you have a picture from your Rochester B vacuum port for me?
Ill snap a photo for you here in a bit. Some quick reading on your truck via the gallery stated that the truck was restored so I assume that the engine was at least freshened up. Without pulling the head its hard to determine if it was bored over during that or just honed.
Full disclosure, I am still playing with all of this to get my engine dialed in where I want it and the afore stated numbers are where I currently am which is the best I've had it since adding the HEI. I had everything dialed in perfect with the points system but adding the HEI and larger plug gap threw everything to the wind and I've been tinkering ever since.
in Gallery Forum
As requested, where I've got the vac line hooked to the carb.
in Gallery Forum
Thank you!! I can work with this.
thumbs_up
If in doubt, send a PM to Hotrod Lincoln. He knows his stuff and mentored me to this point that I am at.
I also recommend using timing tape on the balancer IF you get it set perfect to the TDC mark. Dial back timing lights all seemed to read different from one another when used, so I opted for a standard timing light and timing tape. You can make the tape yourself once you measure the diameter on your balancer.
in Gallery Forum
Insomniac
Insomniac
Make your own timing tape: Timing Tape
Gord 🇨🇦
1954 1/2 ton 235 4 speed
