1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
Long story made short. The key to the '51 truck is hidden/temporarily lost in the shop, can't find it (but will in time I trust). So, rather than having a new key made I'm thinking just wire in a simple on/off switch at the back of the ignition switch until the original key turns up. Just checked my inventory and all I have is a new 120v SPST light switch. Any reason this won't work?
On the good news front, a decades-long delayed shop cleaning and organizing effort is underway.
Thanks, RonR
RonR
1970 340 Duster
1964 CJ5
Insomniac
Insomniac
The switch should work OK. Switch doesn't care if it's AC or DC.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
7
7 Offline
The light switch should be able to handle 10 - 15 amps.
Any on/off switch would work
.. Shucks, you could just twist up the ends of a hot wire to the coil and stomp the starter... crude but effective. (I'm an old farmer. I've seen or done it all. Whatever it takes to get back to the barn.)
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Jethro, I did do that very thing to move the truck from the hay shed to the shop. Jumped from the starter to the coil. Cranks fine, another reason to admire the foot activated starter. Only problem is a lot of stuff doesn’t work. The switch is ziptied to the steering column, just need to wind myself down under the dash and make two connections.
I’m kinda liking how it’s looking. My farm and logging roots are showing!
RonR
RonR
1970 340 Duster
1964 CJ5
B Online: Content
Just don't use a dimmer switch. wink
Moderator, Electrical Bay
Ron, I sincerely hope that goes well for you. In my case anytime I go about a cleaning / organizing effort or project two things happen: I find things I knew I had but couldn't locate and two...my re-organization work means I can't find much of anything anymore. It seems to be worse at this age, also.
~ Jon
Like you, Ron, my battery cover, the first item I bought from another stovebolter, is still MIA. It’s SOMEWHERE in the garage, but hasn’t bubbled to the top yet. Bit I haven’t had time yet to pick the garage up, turn it upside down and shake.
Well, it won’t be long now until the keys float to the top. The 20 amp light switch is installed and working. I suspect the universe will chuckle as the inevitable happens and I find keys in the last place I look.
The only minor very slight concern is their’s a feedback in the system. If the engine is at high idle, it continues to run with the temporary switch flipped off. Slow it to a low idle and the alternator drops out and it dies. I can live with that for a while.
RonR
RonR
1970 340 Duster
1964 CJ5
I've had that happen before. One way around it is by using a solenoid to eliminate feedback but we're heading off into the weeds and making this much more complex than it needs to be. Better to find the keys, I'd say.
~ Jon
B Online: Content
I suspect the universe will chuckle as the inevitable happens and I find keys in the last place I look. RonR
That's better than to continue looking after you find them.
The only minor very slight concern is their’s a feedback in the system. If the engine is at high idle, it continues to run with the temporary switch flipped off. Slow it to a low idle and the alternator drops out and it dies. I can live with that for a while. RonR
Sounds like a job for a 12 volt LED.
