6 members (SmalltownTRKGuy, KEVINSKI, TrknGMC, Millenimech, JW51, Gdads51), 89 guests, and 1 robot.
Topics128,049
Posts1,055,634
#1557064 09/03/2024 1:54 PM
2 Offline
My engine had a stuck valve and it bent the pushrod . Its a 216 car engine the original pushrod has a slice on the mushroom end i guess to let air out of the lifter. If i cant find the correct pushrod could i use 1 from a 235 the shaft is bigger in diameter but the mushroom end is smaller in diameter the length is the same .
Moderator, Electrical Bay
I think you could. Most of the 216 rods I've got are a different length than the 235 rods, though. You might want to make sure. You can straighten the bent one if you have an anvil or a good vise. I've done that before. It isn't easy to get it perfect but patience helps. Good luck!
~ Jon
H Online: Content
A pushrod with a slot in the lifter end is from a 1950-53 spray oiler 235 with hydraulic lifters. It has no business being in a 216. Do the rest of the pushrod have the same feature? Check the block casting numbers and make sure you don't actually have a juice cam 235 in there.
