| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | My engine had a stuck valve and it bent the pushrod . Its a 216 car engine the original pushrod has a slice on the mushroom end i guess to let air out of the lifter. If i cant find the correct pushrod could i use 1 from a 235 the shaft is bigger in diameter but the mushroom end is smaller in diameter the length is the same . | | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | I think you could. Most of the 216 rods I've got are a different length than the 235 rods, though. You might want to make sure. You can straighten the bent one if you have an anvil or a good vise. I've done that before. It isn't easy to get it perfect but patience helps. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | A pushrod with a slot in the lifter end is from a 1950-53 spray oiler 235 with hydraulic lifters. It has no business being in a 216. Do the rest of the pushrod have the same feature? Check the block casting numbers and make sure you don't actually have a juice cam 235 in there. Jerry
