| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Gents,
After watching a TV show where they put EFI on a SBC, I was curious if anyone has put EFI on a 235 or 261. Did it make a difference?
Thoughts?
Chris | | | | | Joined: Oct 2021 Posts: 6,687 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,687 | At least 2 guys on this forum installed Holly Sniper units designed for Ford 200,250 inline six replacing the Autolite 1100 carbuuretor on 216/235 with excellent results.
No major performance increase but no more carburetor issues to worry about.
Do a search on this site to find the threads. Very interesting.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Thanks Otto,
I will go search! | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | My 1970 Volvo 164 had an inline six with Bosch fuel injection- - - - -you might be able to find one decorating a salvage yard somewhere and scavenge up the whole system. I was never so happy to see any car go to scrap after my daughter wrecked it! Jerry
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | | | | | | Joined: Oct 2021 Posts: 6,687 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,687 | I wonder if the last generation of Ford 300 inline six EFI could be adapted?
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I would assume the Ford could be, but I think it is multiport and not a TB design. | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Not wishing to stray too far from the original topic; however the questions were raised about carb to EFI difference, and adapting the late Ford 300 EFI: Dad bought Ford's for 70 years; starting with a 1912. His late 300 van with EFI was horrible. At the same time I had the identical van, granted that mine was a stick transmission, and his was an automatic that was a couple of years older, and carbureted. The EFI made much less power from a LOT more fuel, and I think every electronic device in the EFI failed at least once. He replaced the fuel pump relay 7 times in less than 50k miles. The carbureted version would get 35~40 percent better fuel economy when we traveled in tandem. I would rather have a Rochester B  EDIT: In all fairness, this is my ONLY experience with one of these; it is quite possible this example was merely a production lemon, and not representative of the entire run. Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2004 Posts: 5,069 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,069 | ndkid275 (Chris), et al: I'm passing this to the HiPo area. I bet it can rather even more steam there.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Peggy,
No worries. I was just curious after seeing a TV show. I have no desire to change. I was just curious others thoughts on if it actually makes a difference. There are claims that it will add 10-20% more HP…. Anyone can make claims and I don’t see spending the $$ on a Stovebolt that won’t make a serious difference.
Chris | | | | | Joined: Oct 2021 Posts: 6,687 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,687 | What would you do with all kinds of extra power on an AD truck anyway? It's designed to be driven at 60mph tops. Just because it might be able to go faster doesn't make it something you'd really want to do.
Getting rid of carburetor troubles, especially on a truck that sits around doing nothing all the time, can make it appealing to some people.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Just do what I do with my Harley- - - - -shut off the fuel and run the carburetor dry every time you shut down. It can sit for months without being started, and then start and run just fine when I choose to fire up the engine. Jerry
| | | | | Joined: Oct 2021 Posts: 6,687 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,687 | Carbking has stated that accelerator pump diaphragms that go from dry to wet and back again over and over have a tendency to wear out faster. Keeping the diaphragm submerged in fuel keeps it from drying out and tearing/cracking.
| | | | | Joined: Aug 2010 Posts: 593 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 593 | Someone here posted up the many troubles with Ford 300 straight six EFI. They must have gotten a first year lemon, because when I was a mechanic for a decade, I had maybe two Ford 300 straight six EFI problems that weren't a fuel pump or filter. I'm a Chevy guy, and that setup was one of the most reliable things to ever come out of Detroit. The last one I knew would sit for a year and a half at a time, then fire right up with the first turn of the key after charging the battery.
Would be super cool to find a way to adapt that setup to a Stovebolt. Or at least install injector bungs and make a fuel rail for maybe a Clifford intake. Oh, if only I had time, money, and a big garage!!
| | | | | Joined: Oct 2021 Posts: 6,687 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,687 | Would be super cool to find a way to adapt that setup to a Stovebolt. The Sniper EFI system made for Ford 170/200/250 I6 engines bolts right up to the 216/235 and apparently works extremely well according to a couple people on this forum who have used it.
| | | | | Joined: Aug 2010 Posts: 593 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 593 | Well now that would be the easy way, wouldn't it? ;-)
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | When is a siamese port engine equal to a individual port engine? When the key is off. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | For reference, you can look at the Chevrolet Omega 4.1L that was made in Brazil. A modernized Chevrolet 250 with MPFI. 166 HP at 4500 RPM and 250 lb-ft at 3500 RPM. Gas mileage around 25 MPG. Years 1986 to 1998. The MPFI solved the fuel efficiency problems of the Siamese port. I guess this could be considered the ultimate improvement to a Chevy I6 negating turbocharging (another story). The last time I searched for info, the new designed aluminum cylinder head for the 4.1L had leaking problems. In my opinion, they stopped I6 engine production because there were other more reliable (also probably cheaper) engines available at the time.
It takes a ton of $$$, research and testing to develop reliable fuel systems for engines. Manufacturers of add-on EFI kits do not have the resources that the major automobile manufacturers have. So, I wouldn't be surprised to hear that some Holley (and other companies) EFI kits fail. For example, kits for a Chevy 350 V8s have failed because of faulty capacitors. Heat (typically exhaust manifold), noise spikes from a 12Vdc power source, need for consistent fuel supply (some new 12Vdc pumps fail), wear, on-and-on, are some of the headaches to deal with. Then there is the need to be proficient in setting up the EFI system parameters by computer. A trial-and-error process and if plug-n-play, still need tweaking. To make matters worse, it usually happens that things fail when you are furthest away from home. In that case you need to take all your troubleshooting equipment with you as well as spare parts.
Until enough poor souls have plowed their way forward to creating reliability and can provide empirical information to ease the installation and setup for the rest of us, I'm going to stay with a humble carburetor.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | For reference, you can look at the Chevrolet Omega 4.1L that was made in Brazil. A modernized Chevrolet 250 with MPFI. 166 HP at 4500 RPM and 250 lb-ft at 3500 RPM. Gas mileage around 25 MPG. Years 1986 to 1998. The MPFI solved the fuel efficiency problems of the Siamese port. I guess this could be considered the ultimate improvement to a Chevy I6 negating turbocharging (another story). The last time I searched for info, the new designed aluminum cylinder head for the 4.1L had leaking problems. In my opinion, they stopped I6 engine production because there were other more reliable (also probably cheaper) engines available at the time.
Until enough poor souls have plowed their way forward to creating reliability and can provide empirical information to ease the installation and setup for the rest of us, I'm going to stay with a humble carburetor. Just an FYI, the Brazilian engine you are referencing does not have a siamese port, but a new, individual 12 port head called the "Brazilian 12 Port" here in the states. The intake runners are raised higher on the side of the head by about an inch. The port spacing on the exhaust is the same as the US siamese head, and most everything else is the same, ie...combustion chamber, valve sizes, etc....
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
