1 members (UtahYork), 127 guests, and 4 robots.
Topics128,193
Posts1,057,257
Members48,466
#1556217 08/23/2024 12:43 PM
1 Offline
My fuel pump started leaking a few weeks ago. I found a NOS pump. My truck is a 1955.1 but I am sure the NOS pump is newer, guessing mid 70s based upon the AC box it was in. Would you use an NOS fuel pump without rebuilding it first?
Thanks for any input.
Pedals 3
Paddles 0
The rubber inside is unlikely to have any ethanol resistance, whatsoever. However, I am increasingly skeptical that modern rubber is really any better. In many cases, it’s much worse.
I’d be tempted to run it and see what happens.
I have had decent luck with NOS rubber stuff in other parts of my truck. I’ve yet to try anything that touches fuel, however.
Wonder if you could buy a new diaphragm without a whole new rebuild kit?
1951 3100
Heck no! Even without ethanol problems, that rubber is probably dried out and distorted. Buy the correct rebuild kit from Then and Now Automotive www.then-now-auto.com or send it to them to be rebuilt. You won't regret it.
Here's mine. Three years and 8000 miles later it's still going strong and runs on nothing but 87 deathanol.
1950 Chevrolet 3100 (Ol' Roy)
Carburetion specialist
Only if I had an automatic halon fire system under the hood!
Jon
The Carburetor Shop
