5 members (mick53, Wally / Montana, Peggy M, stlcardinalsguy, Gray_Ghost), 61 guests, and 3 robots.
Topics128,130
Posts1,056,702
Members48,454
#155619 04/01/2002 6:21 PM
I'm wanting a p-washer like everyone else. Can't seem to come up with the $ needed for what I want. I want Gas, at least 2500 psi. I have an import store near me that has "serviced" units quite often. They look new and mostly are, but had a problem that factory supposedly repaired/replaced. They have a Karcher model now on sale for $269 that is a 6.5 hp Briggs and 2300 psi/2.5gals/hr and looks real good. Nice big wheels on cart (air tires) heavy metal wand with replaceable tips, and external brass pump. What worries me is a block diecast "gear" box? or something on engine shaft before the pump. It looks like a right angle drive or something. Are Karcher's generally a good brand? What you think the "box" is? Anyone have luck with "factory serviced" stuff or is it just junk and trouble?
I know Harbor and Northern have a lot of units, just not as cheap and then shipping too. Ideas?
I have used my buddies plastic "cheapie" washer some, and it's OK, just not big enough power for stuff I usually do.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#155620 04/01/2002 7:55 PM
Bought mind at COSTCO which had the best price around, a 2400 psi it's a Karche with a Honda 5.0 engine. Will knock the snot off anything. I bought it last summer to power wash the deck (about 2400 sq.ft.) but I haven't used it much. I unpacked it, set it up and the wife wanted to try it...the next day the deck was finished and looked like new !!! grin I've power washed a couple of engines and was very pleased with the results. This year, I'm looking to get her a John Deere lawn mower. Nothing but the best for the wife grin grin . Good luck.
#155621 04/02/2002 1:35 AM
I found that works for me too. Put-off long enuf and the wife gets mad and gets out the tools and finishes the job I didn't want to be messing with in first place. She Hates me, I Love her! grin
She even helps with truck pushing, holding, pressing brakes and such even though she SAYS she hates it! wink
G.L. Grumpy's
Old Iron Ranch
#155622 04/04/2002 2:44 AM
V
V Offline
If you REALLY want to strip old paint/grease/rust off, I'd get a Hotsy if I were you. They heat up a mildly caustic solution and spray it on under pressure. It's practically the origination of the phrase "Steam Cleaner". You can rent these units too. They clean much better than those cheap pressure washers. You have to wear protective gear when using them, because they do a pretty good job removing flesh also.
#155623 04/04/2002 4:02 PM
If you want to use hot water with the power washer, hook up a garden hose to a water heater and connect the other end to your p-washer. Suppost to work real good. I've never tried it myself, but would if needed to. wink
#155624 04/04/2002 6:49 PM
Good idea!
I'll be putting in an extra tap for the hot water heater in the garage, now that I've read this... smile
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#155625 04/04/2002 9:07 PM
I have a Colman with a 6.5 horse Honda motor 2500 psi. It was about 400 bucks at Sam's. (Wal-Mart discount club). We have used it over and over with no problems. We now have two restaurants we go over eveerything in the kitchens with it every weekend gets all that grease off with no problem. grin
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
#155626 04/07/2002 5:20 AM
Quote
And i got excited about the one i seen on t.v. the other day.They marketed it as a household appliance and were using it in the kitchen.Cleaning the oven and steaming veggies at the same time. Only 3 easy payments of $39.95 and it was mine.
grin grin grin
#155627 04/10/2002 1:00 AM
My uncle has a hotsy on his farm- oil burner, 220 electric motor, will strip paint if you are not careful. You can't leave the burner on too long or you will just get steam.
Paint & Body Shop moderator
#155628 04/10/2002 1:47 AM
BOYO-ijust hook my garden hose up to the spigot on the bottom of my water heater.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#155629 04/11/2002 5:16 AM
Anonymous
Unregistered
Anonymous
Unregistered
Here is one for you . . . I have a buddy that just got a huge order to build pressure washers that force water through a flash freezer and combine with air pressure for making an ice blaster! They use this to clean up transmission gears right after machining at FQRD rather than using solvents and dealing with all the environmental issues. He has orders for over 100 units! Who sez you can't make it big if you have a good idea! smile
#155630 04/16/2002 9:31 AM
Well, today I bought the unit I told about in first post here. Haven't read up on it or got out of box yet. Just "Havin'" it is good enough for me for awhile! grin Anyway on way home wife asks about cleaner for it and mentions the deck and siding and .....Where's she gettin' THOSE ideas? This is for Truck/garage use, Sheesh! :rolleyes:
G.L. Grumpy's
Old Iron Ranch
#155631 04/21/2002 6:42 PM
Ran washer yesterday! It worked fine for 3 minutes, then the pressure dropped off bad. Then I messed with it some and it came back and never bothered again. Has 3 position tip. One for slow app of cleaner/solvent, one for medium wider blast that is pretty strong as is, and one for direct/high press blast, only cleans about 1/2" spot though! :rolleyes: Most stuff will use the wider spray. Sure has a "kick" to it. Wife had to try it too and almost dropped wand first time she used high press setting. Was Funny!...to ME anyway! grin Maybe she won't want to use it so much now! smile
G.L. Grumpy's
Old Iron Ranch
#155632 04/30/2002 6:22 PM
a poor mans method---and a very old one, is those blowgun type sprayers that hook to the water hose and air lines. certainly not as fast, but for alot of things will work---cheap. with the hot water----------hmmmmmm, i wonder cool
Moderated by  MNSmith
