3 members (68ironhead, 49nut, 1 invisible), 49 guests, and 1 robot.
Topics128,049
Posts1,055,691
#1555958 08/20/2024 7:42 PM
Wiring my 54 3600. Changing to 12 volt. New auto wire harness. 12 volt stater and generator. Do I need a ballast resistor between ignition and coil?
Only if you want the points to last more than a few weeks. The operating voltage for a "12 volt" electrical system will be around 14.5 volts against a fully charged battery. Points need to have a current flow of less than 5 amps, which usually happens with about 9.5 volts applied to the coil primary winding. That's why a resistor is needed. When the starter is operating, the "12 volt" battery has a terminal voltage of around 9V due to the load of the starter. A correctly wired 12V ignition system will have a bypass switch that puts full battery voltage to the ignition system during cranking.
Justice #1555970 08/20/2024 10:46 PM
I think Jerry said "yes."
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
