3 members (Brian Moore, klhansen, wilbur53), 100 guests, and 2 robots.
Topics128,126
Posts1,056,356
Members48,441
TomStenger533600
TomStenger533600
Hi all, I haven't been on in a while and finally getting my '53 3600 216 running.
The Carter YF carb had issues, so I took it apart, cleaned and rebuilt it with a kit from the carbking.
All seemed fine. I'd adjusted the linkage for choke and throttle and it ran fine for at least fifteen minutes a few months back
Next time- recently - tried it and it wouldn't start: just crank, or fire sporadically try, then sputter, and nothing.
I've checked most of the potential problem causes ignition, timing, fuel filter, lines, pump...) and am wondering about the throttle plate:
Potential Issue? ==>. there is a slight (maybe < .5 mm) gap in the throttle plate when it's closed (I had to rethread the shaft). Is that contributing to or the main problem? flooding at startup
Thanks for any feedback and thankful for the Stovebolt Forums :^). Tom
TJSting120273600
Carburetion specialist
There might be an issue with the throttle plate, but it is probably not the issue causing the engine not to start.
Is the fuel a few months old??? Old fuel is difficult to start, and will probably burn poorly until the engine is hot.
Have you tried starting the engine using starting fluid?
Jon
The Carburetor Shop
TomStenger533600
TomStenger533600
Yep, the fuel is between two and three months old. I'll empty that and give it a fresh start.
Thanks Carbking!
Tom
TJSting120273600
