1 members (Peggy M),
39
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 4 New Guy | | New Guy Joined: Sep 2007 Posts: 4 | Hi...I have a 64 frame with a 65 cab on it. I was looking at replacing the cab with one that was in better shape. Mines not a total waste...but needs metal. When I bought truck it was painted and looked good. Rust starting to cone through. Front of hood,Botttom of fenders,driversside roof in corner,center of back glass has a few bubbles. Cab supports look rough. Im searching for a cab without alot of these problems even though mine is fixable. I found a c-60 someone is parting out. I havent seen the truck (would have to ship)but if it is almost rust free...is this the same body? I know fenders are different...cab looks the same. Any guidence would be greatly appreciated. | | | | | Joined: Nov 2006 Posts: 10 New Guy | | New Guy Joined: Nov 2006 Posts: 10 | The cabs are the same,if there's any differences it'll be cab mounts due to the c60 frame. hopefully someone who knows this for sure will chime in T
I got lost in thought It wasn't familiar territory
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I have never tried the swap, but I have also heard that the cab mounts and sections of the floors are pretty much different.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If its a conventional cab & not a LCF it will work, you will need to drill the floor for 1/2 ton frame mounts & move the mounting washer to that location If its a LCF(has a short hood & lower front edge of doors are cut off) all bets are off as floors/fenders all diff | | | | | Joined: Sep 2007 Posts: 4 New Guy | | New Guy Joined: Sep 2007 Posts: 4 | Sounds like I need to keep searching. I thought I could atleast use the hood...dowt!@#%.....hehehehe...thanks for the 411 fellas  | | |
