6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#155530 10/24/2007 6:58 AM
Hi...I have a 64 frame with a 65 cab on it. I was looking at replacing the cab with one that was in better shape. Mines not a total waste...but needs metal. When I bought truck it was painted and looked good. Rust starting to cone through. Front of hood,Botttom of fenders,driversside roof in corner,center of back glass has a few bubbles. Cab supports look rough. Im searching for a cab without alot of these problems even though mine is fixable. I found a c-60 someone is parting out. I havent seen the truck (would have to ship)but if it is almost rust free...is this the same body? I know fenders are different...cab looks the same. Any guidence would be greatly appreciated.
#155531 10/24/2007 12:27 PM
The cabs are the same,if there's any differences it'll be cab mounts due to the c60 frame.
hopefully someone who knows this for sure will chime in
I got lost in thought
It wasn't familiar territory
#155532 10/24/2007 1:29 PM
I have never tried the swap, but I have also heard that the cab mounts and sections of the floors are pretty much different.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
#155533 10/24/2007 1:51 PM
If its a conventional cab & not a LCF it will work, you will need to drill the floor for 1/2 ton frame mounts & move the mounting washer to that location
If its a LCF(has a short hood & lower front edge of doors are cut off) all bets are off as floors/fenders all diff
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#155534 10/25/2007 7:46 AM
Sounds like I need to keep searching. I thought I could atleast use the hood...dowt!@#%.....hehehehe...thanks for the 411 fellas smile
