| | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | I know that was accepted norm with a 216, but with "full pressure" 235 wasn't that pretty much eliminated? Lotsa full pressure folks eventually change insert bearings without removing crank, but the need for that wouldn't arise for how many miles (assuming frequent oil changes)?
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I ran mine about 200,000 before I changed the bearings in-frame. 55 2nd 235. It always had a filter and mostly highway miles. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | A Cummins Diesel field trainer was teaching a seminar on engine maintenance to a bunch of yacht owners at a marina where I used to do a lot of electrical repairs. When somebody asked him how long a Cummins engine would last, he replied "Long enough to eat 10 pounds of dirt!". He was emphasizing that regular oil and air filter changes have a huge impact on engine life. 10 weeks- - - -or 10 years- - - -or 50 years- - - -it all depends on how clean the owner keeps the engine.
Adjusting Babbit bearings with shim stock was a routine job, usually done during a "ring and valve job". The piston rings in the 40s and 50s were the weak point, and they usually failed long before the rod and main bearings did. Precision insert bearings can't be shim-adjusted (or at least it shouldn't be attempted), so keeping the oil clean and dust out of the intake will be the determining factor for bearing life on engines since the mid-1950s. Jerry
