3 members (Gray_Ghost, Steelonsteel, Gdads51), 46 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#1555076 08/10/2024 10:20 PM
I'm trying to decide whether I want to paint my 66 C10 back to factory (saddle two-tone) or leave her with the patina she has now, and I figured the condition of her current paint is a good place to start. I don't think her paint was ever stripped and she's had at least 5 full paint jobs. The paint flakes in places and leaves your gloves blue-white in others. If the paint is recoverable enough for preservation, what would be the best way to prep her for that?
There's nothing to "preserve". Either drive it as-is and let it continue to age, flake, and peel, or strip it to the metal and paint the entire truck properly.
1950 Chevrolet 3100 (Ol' Roy)
Jacob, Welcome back from a fellow MO Bolter! thumbs_up Your question basically comes down to what do you want the truck to look like when finished??? If you like the patina, you can remove the loose/flaking and chalky paint with a good power wash and scrub down and then coat it with one of the currently available "patina preservers" which provides a coating to basically seal and preserve how it looks today. If you want a nice factory style paint job, then you must do the whole strip down, body work/paint prep and full repaint process.
Either way, it's your truck and your choice. What ever makes you happiest! thumbs_up
~ Dan
1951 Chevy 3 window 3100
With 5 previous coats of paint that are checkered and peeling, It's going to be pretty hard to stop that. But if you're happy with how it looks, Dan's suggestion of a "patina preserver" might work for a while. I'm not familiar with them.
If it's a nice straight truck other than the paint peeling, then I'd lean toward stripping it and starting fresh. But it's your truck.
Welcome to the Stovebolt Forums.
AD Addict & Tinkerer
I agree with Kevin. Unless you get under those rusty areas, they will continue to rust and flake off. “Patina Preserver” may slow the process but it won’t stop it. Assuming that you showing us the worst of it, you may consider removing the flaking paint/bondo/rust in those areas, replacing any rusted thru areas then try to recreate the patina yourself to match the existing.
If you don’t feel you have those skills, there are shops that could help.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks for all the advice. This will help a lot as I mull it over
