| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I’m getting ready to have my front clip and bed components sandblasted and I want to apply Epoxy primer. I went to my local Auto Body Supply and was floored when he quoted $360 for a gallon. Stated that the prices jumped big time when they changed the formula to comply with new VOC regulations. I looked on line and it looks like $200 would be more in line for a gallon.
Do any of my fellow ‘Bolters have any recommendations?
I’m also looking recommendations for body filler.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | I use Evercoat primer (in the summer here I use common lacquer primer...way too hot to use catalyzed primer and the old style stuff is a bit less $$$). As for body filler, it is expensive but I use Evercoat Easy Sand (think it is part number 421). Last catalyzed primer I got was something like $210 a gallon...last lacquer primer was maybe $180 a gallon. Cut the lacquer 1.25 thinner to 1 part primer in the summer and a nozzle of around 2mm. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | I have used PPG products since the '70's, I still like the quality of the product, as long as you stay with the manufacturers line of products, I think you would be fine with any of the major brands.
| | | | | Joined: May 2015 Posts: 11,023 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,023 | I’ve used PIP302 epoxy primer from NAPA. Their paint is manufactured by Martin Senour. I think it cost me a touch over $200 for a gallon with the hardener. I believe it’s a low VOC product.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | So to wrap up this thread, I ordered and received epoxy primer from Eastwood. A 2 gallon kit of primer and catalyst for $230, plus shipping and tax. I had a 10% discount code which totaled out to $250.
I’m picking up some of my sandblasted parts tomorrow so we’ll see how it goes.
