8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible), 74 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
Page 19 of 20 1 2 … 17 18 19 20
24601
24601
I picked up a DeWalt 20V portable compressor recently. The literature claims it goes up to 160 psi. I took it to work yesterday and used it to air up the problem tire on my work truck (leaky valve). It did 120 psi no problems. Took awhile but I was able to dial in 120 and go finish my pretrip while the compressor did its thing.
New compressor
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Sounds like a robust and very useful tool. I've been given several electric tire pumps over the past few years by well meaning kids (Xmas, B-day, etc.) and all failed within the first few uses just airing up a standard truck tire to 32 psi. Sounds like a worthwhile investment. Thanks!
~ Dan
1951 Chevy 3 window 3100
Crusty Old Sarge
Crusty Old Sarge
We had our county wide yard sale this weekend. Lots of folks with lots of junk. I found a couple of things I just couldn't live with out. A vintage Craftsman tool box, still had the tray inside. I also picked up 2 vintage "C" clamps, both are pretty old.
Craftsman Tool Box
Cincinnati Tool Co clamp
Armstrong Tool Co clamp
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
There is no such thing as "too many" C Clamps. I need snag some more as my selection has some size gaps.
1951 3100
JW51, Don't you mean "There's no such thing as "too many" TOOLS"? wink
I've always said it's a lousy project that doesn't require a new tool.
24601
24601
Wally -- THAT is the quote of the month!! I am *so* using that!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
A 4 post lift. All I need now is a shelf for my Chilton and Time Life mechanic's books. eek
1951 Chevrolet 3600 | 1966 Pontiac Lemans/GTO resto-mod
O Online: Content
Your garage is nicer than my house.
1950 Chevrolet 3100 (Ol' Roy)
This. smile
To relocate the flange inward to clear the steering.
Stick welding is not fun.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
A Multi-process welder? NICE!
Always wanted one.
Next step. Practice TIG to do the exhaust.
Practice, practice, practice.
Chip
'Rusto-Mod'
AD Addict & Tinkerer
I’m getting ready to pull the glass out of my cab so I can remove rust from under the rubber seals. I went to HF to buy a couple of suction cups for handling the glass and to my pleasant surprise, they were on sale for $2.99.
Here is a link.
Phil
Project Journals
Stovebolt Gallery Forum
Got a pair of bit sets from the new Mac distributor. One of them came with a mini driver. I also picked up an axle bearing extractor. Seemed to be a smart thing to do with all the axles I've been working on lately. Also picked up a hole punch set for home.
John, that sounds like a good addition to any road warrior's collection. Red Simpson said it well- - - - -"I'll just have a flat on an inside dual- - - - -that'll show him!"
www.youtube.com/watch?v=1_u8QtYcEo0
LOL!
Got a deal on a pair of air angle die grinders. Also picked up some exhaust tube spreaders. And, a specialty tool moving/aligning the arms on a 2 post in-ground lift. I'm not as limber as I used to be.
I've been investing in some heavy duty shop equipment- - - -a sheet metal brake, a 20 ton hydraulic pipe/tubing bender capable of bending roll bar tubing, a transmission jack, and an engine stand with a gear drive rotator to keep from having to manhandle a stovebolt block when I want to turn it sideways to install pistons, or upside down to torque rod and main bearings. I might be getting old and feeble, but old age and treachery can usually beat youth and exuberance!
8
8 Offline
A new mig gauge, mine was acting up.
~ Old truck enthusiast
1948 Chevy 5-Window
"From a load of parts ..."
See it in the DITY
1955 Chevrolet Cameo
"Ol' Blue" - "A 'good home'"
Follow in the DITY
Got me a Dewalt battery powered grease gun for Christmas!!!!!!!!!!!
That orta extend the validation of my Man Card for 2-3 years I'd guess.
Carl, I got one of those for my Son-in-law last Christmas after he bought a Bobcat for snow removal. It apparently has a ton of zerks on it that need to be greased. It was the beefiest of the ones I looked at.
Lincoln 215 MPI…. Been eyeing that, I think one will be in my shop this week, the welding shop is across from the muffler shop…
They have a $400. Factory rebate right now making it $1600….
What hood are you using, vision is so critical, especially to tig….
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Did a little clean up. Topic back on course.
I probably already have a few, but I picked up a compound wire crimper with multiple jaws that can be changed out per type of terminal. Got it for all the non-insulated open barrel connector terminals I need to crimp.
Former Workshop Owner
I went and purchased a Noid Light set for $25 from Amazon. Turned out to very handy checking out the fuel injector leads on my daily driver. I could have used a volt meter, but this was quicker.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
24601
24601
Kevin -- Your SIL will most likely be getting in the dirt with his skidsteer eventually. Another tool to have for those zerks is a grease fitting rejuvenator. In the excavating business, we found this tool to be a must-have. Besides ... they're kinda fun to use smile If you don't mind spraying yourself with diesel fuel or penetrating oil from time to time...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Thanks for the recommendation, John. I'll pass it along to him.
Picked up a 1/4" drive, flex head ratchet, but a long handle version. For my bellhousing to T5 adapter, I installed it with some 12 point 3/8" bolts at the upper two holes. I had to make a new adapter and instead of removing the clutch assembly, I was able to barely fit my hand in there to remove and install the two 12 points. But how to tighten them? I thought I needed the 1/4" drive but found my 3/8" drive, long handle flex head did just fine. In the future, I'll have multiple choices for install and removal. Discovered I needed more 12 point sockets, so I added a 1/4" drive set to the home box.
I just acquired an old snap-on rachet. It could be as old as 1927. it still works as designed.
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
back
The USAF issued me a 3/8 drive Snap-On ratchet with an almost identical handle shape in the late 1960s- - - -the only difference was that it had a lever to switch directions instead of the square drive that can be inserted from either side.
Jerry'
B Online: Content
Yours was probably a model 71 Jerry. Pictures below swiped from an eBay add, but may be interesting for someone.
1st picture is of a "government #71".
2nd picture is the back of the same ratchet, showing the date code near the "on/off" selector.
3rd picture is the magic decoder ring for Snap On date codes.
Tiger tool u-joint puller.
Former co-worker let me try his to replace a joint on my '99 Tahoe, original joint with 352,000 mile on the clock so it was pretty stubborn.
Works really slick.
Built by our Canadian friends!
Wish I had on during my working career, could have been a real $$$ maker on flat rate!
BC
1960 C60 pasture art
I have one, they work great and I wouldn't let my co-workers borrow it. Every once in a while I would loan a tool and it came back broken or had stripped threads or something else wrong with it. And of course they wouldn't replace or repair it.
1936 GMC T-14 restro-mod
Had no issues replacing one of the original joints in my '99 Tahoe with 352,000 miles on the clock.
Seems to there's always someone in the shop that could screw up an anvil.
BC
Need to do the main seal on my 302, so I picked up ye old seal installer tool.
24601
24601
Maybe truck related .... sortta ... kinda .... as in if I get some projects done for miss Peggy, she'll let me get back to old truck stuff ...
Anyway ... went over to Huntsville Thursday and got a 1968 vintage Rockwell-Delta wood lathe in near new condition.
smile
New (to me) Rockwell lathe.
Unloading from the trailer
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Purchased a one man pressure brake bleeder. The type with a plate that straps on the top of the master cylinder. Comes with very small chains that easily break when tightened to seal the master cylinder. Replaced them with the chain cut off a horse lead and it now seals great. Easily took care of a chronic bleeding problem with my ‘57 Bel Air disc brake conversion. You pump it up like a garden sprayer , then go to the individual wheel cylinders. Super easy one man operation. Should work great on our old trucks.
B Online: Content
Make and model of the bleeder please.
Bill, if I could I would. I just googled pressure brake bleeder and several came up on the jungle website. Read the reviews and purchased the middle of the road model.
“Orion Motor Tech brake bleeder from Amazon.”
B Online: Content
Thanks. I have a 70 Mustang disk/drum master cylinder (has built it residual valves) in my '52 GMC. I can't find a Orion Motor Tech bleeder for my master cylinder, but just sent their tech support group an email. We'll see.
Picked up some carbide gasket scrapers. Supposed to be the cat’s meow. We’ll see when I finish scraping the oil pan gasket off of the 302.
Moderated by  MNSmith
