the attached pic is the pushrod out of my 63 c 10.
i replaced the mc with a new one that appears identical to the old one.
including the piston where the push rood pushes.
by the time i have the push rod adjusted for pedal travel before piston travel there are maybe 2 threads left holding the rod to the adjuster.
i looked up mc push rods. none of the replacement rods even looks remotely like this one
i did find extenders.
i'm thinking of just making a longer rod.
any insights would be appreciated
thanks
rolf
1963 c10
