1 members (k2handyman), 74 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#1554498 08/04/2024 2:00 AM
Question regarding installing new wheel studs
About to install new axle shafts and need to know proper way to install the studs pound them in with a hammer or use an impact gun? First time doing this job.
This is no longer fun
Professional procrastinator
Lisle 22800 Wheel Stud Installer. I got one these and it was slick as a whistle. Made the job simple and easy.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
latroca52 #1554507 08/04/2024 12:40 PM
Moderator, Electrical Bay
I second the Lisle wheel stud installer. I just used a common wrench, a bit of grease and some oomph. I see they're a lot more expensive today, though.
~ Jon
latroca52 #1554509 08/04/2024 12:57 PM
AD Addict & Tinkerer
They have them on eBay cheap.
Phil
Project Journals
Stovebolt Gallery Forum
I use a ball joint press. It has a variety of adapters, and all the force is applied to the splined base of the stud- - - -NOT the threads.
www.ebay.com/itm/264896339011?
I use an air hammer as long as you can get to the backside. If the axle is in the housing then I use a stud installer.
1936 GMC T-14 restro-mod
