| | | Forums66 Topics128,032 Posts1,055,438 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Question regarding installing new wheel studs About to install new axle shafts and need to know proper way to install the studs pound them in with a hammer or use an impact gun? First time doing this job. Thanks
This is no longer fun
| | | | | Joined: Apr 2020 Posts: 322 Professional procrastinator | | Professional procrastinator Joined: Apr 2020 Posts: 322 | Lisle 22800 Wheel Stud Installer. I got one these and it was slick as a whistle. Made the job simple and easy.
1947.2 GMC 1/2T SWB panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T short bed
| | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | I second the Lisle wheel stud installer. I just used a common wrench, a bit of grease and some oomph. I see they're a lot more expensive today, though.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | They have them on eBay cheap.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | I use a ball joint press. It has a variety of adapters, and all the force is applied to the splined base of the stud- - - -NOT the threads. www.ebay.com/itm/264896339011?Jerry
| | | | | Joined: Oct 2012 Posts: 332 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 332 | I use an air hammer as long as you can get to the backside. If the axle is in the housing then I use a stud installer.
1936 GMC T-14 restro-mod
